Creo 2 M120 Learning Connector
WayneBeck
Has anyone seen this issue and figured out how to fix it. When you click on the learning connector in the upper right hand corner of the Creo window it does not expand. This appears to be a regional issue. I have verified there is nothing in the config.pro to turn it off. I have checked the Java version on the machines that it does not work on. If when you start creo for the first time and hit yes show me the learning connector opens up and works. But if you select no and check do not show again these people cannot get back into learning connector. I have included an image of a working icon.
0 REPLIES 0
