Creo 3.0 Uninstallation through SCCM
VC_9931252
I am using Creo Parametric 3.0 M150
I have been working with Admin team on the Creo 3 uninstall. I am going to need your help. The uninstall command that is listed in the registry is C:\ptc\Creo3\Creo 3.0\M150\Parametric\bin\uninstall.exe and when I look at the switches for this .exe a /Q will let it run silent. When running this command with a /Q or without it does not remove the product. Do you know if additional switches are needed or is there an uninstall order that needs to happen before removing the M150?
Try using "uninstall.exe -quiet -all".   Uninstall.exe will launch pimuninstall.exe, so we need to monitor pimuninstall.exe to determine when the uninstall process is actually complete.
Dan N.
