We just bought Creo 3.0 and our client is using Creo 2.0. Since there is no way to save in 2.0 format from 3.0, can we gain access to the older 2.0 version so we can send files back and forth?
go to https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=ENG
and log in to PTC Support.
You will see following page:
MH
You can open older versions with Creo 3.0, but there is some software that you need for them to open it back in Creo 2.0.
You could always download and install the version they are using if you are on maintenance. Then you can share as much as you like. You just have to make sure you open/save their files in the same version. (Maybe different folders in you network.) A lot of engineering services companies have to do this so that they are working on the same version as their clients.
How do we download and install the older version?
Nancy,
You can download and install Creo 2.0 and the current license (For Creo 3.0) is downward compatible hence same license file or server can use for Creo 2.0
Mahesh,
Great, how exactly do I download the Creo 2.0 install files?
Log in to PTC.com support and go to the software download page.
https://support.ptc.com/appserver/cs/software_update/swupdate.jsp
You can use the link shared by Stephen, make sure your web account is verified and have permissions.
MH
Hi..
you can open and save creo3.0 data in creo2.0, For that you need to copy readnewermodels.dll from "C:\Programme Files\Creo 3.0\M090\Common Files\x86e_win64\gcri" ( your creo 3.0 installation folder ) to "C:\PTC\Creo 2.0\Common Files\M080\x86e_win64\obj" ( your creo 2.0 installation folder).
or you may share your creo3.0 readnewermodels.dll to your client.
Prashant Pandarkra
Nancy,
Did you get the answer of your query? If yes, please mark appropriate reply to post as correct answer.
Yes I got the answer, Thank you MartinHanak!
