Creo 3, M040
I'm having issues with lighting in Creo 3. I have this in my config to tell Creo what lighting scene to use:
default_scene_filename P:\config\01_user\doug\creo_3\Basic-studio-blend-gray.scn
I saved that "Basic-studio-blend-gray.scn" file out of Creo 3. I did this in Creo 2 and it generally worked well, although I would occasionally have to reset the scene because Creo had forgotten.
In Creo 3 the lighting changes all the time. I spin the model 180 degrees and the near side is in the dark. If I reapply that scene it comes back to normal. I tried with and without the "lock room to model" box checked with no difference.
How do I get my lights to stay put?
