Creo 4.0 mistake 0x06000012
Vend
3-Newcomer
Hi!
For a few days ago i have upgraded my Creo Parametric 3.0 up to 4.0. When i try to open it, it says that quality agent could not run and all crashes. I have win 10 and M020 version of Creo if it has something to do with the issue.
Lemons
7-Bedrock
(To:Vend)
Hey,
I just had the same issue as you after installing Creo 4.0 for the first time (0x06000012).
In my case I deinstalled the quality manager from within the downloaded folder:
(...\MED-100WIN-CD-410_M030_Win64\install\addon):
1. Right click on "qualityagent_64.msi"
2. Select deinstall
Afterwards I reinstalled the the quality agent, but I had to change the directory!
1. Again right click on "qualityagent_64.msi"
2. Change directory from "C:\Program Files (x86)\PTC\Quality Agent" to the 64bit folder where the rest of Creo is installed as well.
"C:\Program Files\PTC\Quality Agent"
3. Finish installation of quality manager.
4. Start Creo and it worked.
Maybe this helps someone.
Best regards
9 REPLIES 9
Lemons
7-Bedrock
(To:Vend)
Hey,
2. Select deinstall
Best regards
vladC1
2-Explorer
(To:Lemons)
worked for me, thank you very much!
IB_9795124
2-Explorer
(To:Lemons)
Worked also with my 7.0 student version! Thanks!
How did you re install the quality agent?
please read https://community.ptc.com/t5/PTC-Academic-Program-Discussions/Licensing-Error-Creo-7-0-2-0/m-p/708655 discussion.
Martin Hanák
JP_9890312
2-Explorer
(To:Lemons)
@Lemons you just saved my 90 mins of uninstalling, downloading, reinstalling. It worked! Thanks a lot🙏🙏🙏
I just tried these steps with my newly downloaded Creo 10 student, and technically the process was successful (ie. Creo stays open and appears to have full functionality) so thankyou!
However, I still get the 1st of the 2 errors (that I showed in this post linked below) which states "Creo Agent did not initialize correctly...". For now, I suppose it doesn't matter since my Creo is working, but this distinction feels worth noting.
"Creo Agent did not initialize correctly" error - ... - PTC Community
Worked for me after trying everything else. Ty
