I am using Creo Parametric Release 7.0 and Datecode7.0.5.0
We are trying to create a layout in creo 7 but its not its not working.
please explain us how to work on it
Hello
Maybe your question is too vague.
Note that Creo 7 Layout is used to interactively try out concepts and develop a 2D design layout for use in a 3D application.
Please specify your request:
Is it about an example in the Creo Help Center > Layout topic, while the example is not applicable or is simply missing?
Is it a use case you're just beginning to solve with Creo Layout?
Are you looking for online training for self-study?
Or is it something completely different?
E.g. Does it refer to Creo Notebook, formerly known as "layout", or to the layout of a drawing?
Hello
