Creo Config File Issue
dgschaefer
I noticed this week that PTC marked the SPR related to saving multiple
config files [1] resolved in Creo 2 M030, due later this month, which
was expected.
What wasn't expected is it's also marked as resolved in Creo 1 M050,
which has been out since the beginning of last month. I didn't think it
was going to be resolved in Creo 1 at all.
Since this was a bit of a deal breaker, or at least a source of
frustration, for many I thought I'd let folks know.
[1] - https://www.ptc.com/appserver/cs/view/spr.jsp?n=2095844
LinkedIn
davehaigh
(To:dgschaefer)
I downloaded Creo 1.0-m050 and installed it so I could check the behavior of the config editor.
1. I can view specific config files
2. When I try to edit a specific config and save, it saves everything to the config file.
So in my opinion, it's not fixed properly. I don't know what TC dealt with PTC on this but I believe they didn't communicate clearly what is required. It's still broken.
What I did:
Open the config editor
Select from the pull down the config.sup
[cid:image001.png@01CDBE52.A0E57380]
It now shows me only the config.sup. That is a big improvement!
[cid:image002.png@01CDBE52.A0E57380]
I next pick the Add... button and the Find... button search for something and added it to the config.
[cid:image003.png@01CDBE53.2EC29700]
So far, so good. Looking like I expect it to work.
I pick OK, the only button that looks like it will save my edit for me.
I get this message:
[cid:image004.png@01CDBE53.801C1720]
I believe the correct answer is Yes
In the save dialog, I had to browse to the loadpoint. And then it would not show me the existing config.sup so I had to type the name in manually.
[cid:image006.png@01CDBE54.9647F180]
I then go back to the config editor to look at the config.sup again and I see this:
[cid:image005.png@01CDBE55.53DB7000]
My new option was at the end of the file.
David Haigh
