Creo Parametric Drafting
PB_9460647
2-Explorer
I am using Creo Parametric - Release 5.0 (connected) Release 5.0 and Datecode5.0.0.0
Automatic Pop-up:
In Creo Draftings :- Pop-ups should appear asking for the details of drawing name/file name, size, scale.
By the way, you can bring all your ideas here: https://community.ptc.com/t5/Creo-Parametric-Ideas/idb-p/creoparametric
StephenW
(To:PB_9460647)
If your drawing formats use tables that call for parameters in the model that are not available, then Creo will prompt you for the value for those cells.
I think you (or your company) are lacking in your creo setup.
