Creo Schematics Designs out-of-date in WWGM when connected via VPN
dmartin
11-Garnet
Has anyone else had this experience: when accessing Creo Schematics designs in the Windchill Workgroup Manager when connected via VPN, do your designs show up as out-of-date?
I'll work on a design, and regardless of whether I check it in or not, when I go home and try to access it on my company's VPN, it shows up as out-of-date in WWGM. And I can't update it, because it's not actually out of date.
The workaround is to check everything in before I leave work, and then when I get home, create a new workspace and add the objects to it, and then check everything in before I go back to work. That last part might not be required, but I'm getting into the habit of separate workspaces for home and office.
It's a nuisance, and sometimes you leave work and for whatever reason, don't check everything back in.
I plan on filing a call with PTC, but (1) I wanted to see if anyone else has experienced this, and (2) I always get the same response from PTC: provide us a copy of your data and we'll attempt to reproduce. (We can't share any of our data with anyone.)
gkoch
(To:dmartin)
Hello David,
If this issue is specific to this one design you currently work on, then PTC Technical Support will need this data to make any reasonable investigation.
But if the issue appears with every design of yours, it should be easy for you to create a simple, small example which you can share with PTC.
Gunter
