ProductView support - I have never used ProductView in the past. I have people asking me if we can support ProductView, is this something that can be loaded at each machine or do you need a server to source all the Windchill Objects so that it can be vie
cying
Trying to understand how ProductView is being supported.  Many years ago, I believe you need a separate server and source the objects in Windchill/PDMLinks so that users can view the ProE objects without using the actual proE license.
Can ProductView be loaded at the client's machine and be able to open up a ProE object directly from Windchill?
huggre
(To:cying)
Hi, you dont need a Windchill system to use CreoView.
The CreoView application is installed localy and you can open files from any source.
