Hello everybody,
I come to you today because I had a problem just after installed 3D connection app, always when I start Creo 7 I get these two windows:
How did you manage to solve this error.
Thank you in advance.
Thank you for your advice, at end what it solve my issue was:
1. Copy the file “C:\ProgramData\PTC\«Creo Version»\Plugins\3DxProEngineer\protk.dat” to “C:\Program Files\PTC\«Creo Version»\Common Files\«datecode»\text”
2. Delete the folder “3DxProEngineer” in “C:\ProgramData\PTC\«Creo Version»\Plugins”
Greetings
open protk.dat file mentioned on first picture in Notepad and verify validity of all paths.
the path is correct
There are several reasons and I'm not sure based on these errors.
Greetings
