Creo View 2 M040 Install Error
llie
All,
Has anyone experience this issue when installing Creo View 2 M040 on
Windows 7 x64 with Java 7?
Work around so far is to uninstall Java 7, reinstall Java 6 (1.6), install
Creo View and then reinstall Java 7 which is being pushed out by our IT
department.
Lance J Lie
Information Technology
SAS IT Info. Solutions App. Eng.
Space and Airborne Systems
Raytheon Company
+1 310.616.1551 (office)
+1 310.426.4968 (cell)
+1 310.647.0315 (fax)
2000 E. El Segundo Blvd.
El Segundo, CA 90245 USA
www.raytheon.com
Raytheon Sustainability
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
1 REPLY 1
Tundra
(To:llie)
Lance -
Yep. Had the exact same issue this past Tuesday.
PIA
~John
