Distributed Batch error -23
HiperScan
Hi at all,
I am trying to export several drawings to pdf files using the "PDF DRW Export based upon external profile" . As configurations files I am using
  • config.pro
  • search.pro
  • pen table file
So far I got an error -23 every time I tried to export PDFs. I attached the log-file.
I am using Creo 4.0 M050.
Does anybody know if this SPR is still valid: https://support.ptc.com/appserver/cs/view/spr.jsp?n=6700781
By the way: Exporting multiple part files to STEP files works without any problems!
Thanks for any advice!
Docserta
(To:HiperScan)
I have a same problem.
Cordialy
OPERATION | STATUT | COMMENTAIRES
Connecté à Creo Pro | Réussi | C:\xPTC\Creo 4.0\M050\Parametric\bin\..\bin\parametric.psf
Lecture de la définition du type de tâche | Réussi |
Chemins de recherche ajoutés | Réussi | "wtpub://Production/Produits/Produit test Recette/4 - Etudes/"
Charger le modèle dans Creo Pro | Réussi |
Exécution de la tâche du modèle | Echec | [-23]
Statut de la tâche : Echec
