Drawing Formats Lose Parametrically Linked Tables
ptc-5937530
Sheet 1 of a multi-sheet drawing works fine i.e. the title block fills in properly with the data contained in the model's parameters. When I add sheet 2 to the drawing, it's title block does not fill in because the tables that are superimposed over the 2-Dtitle block graphics that look for the model's parameters are now gone. Is this a config setting or something? I've tried replacing the format, but that did not help. Thank you for your help. --Fred
0 REPLIES 0
