Exception - code was -1073741819
GrahameWard
Is there anyone here who has not had a crash with this error code showing up in their std.out file at some time in their career? Does anyone have a definitive answer to how to fix this? I have gotten this message at different times since release 2000i2 at least, on different computers and different operating systems, different graphics cards, in different countries.
7 REPLIES 7
I have not had that code... Usually it's: glxMakeCurrent 1073283066 exception 1073741787 and the occasional blue screen: nv4_disp.dll de321617 base de1d5000 address The suggested fix "updating the video card driver" has no effect.
GrahameWard
(To:dhoeschen1)
Your's is certainly more complex and subtle than mine The usual suggestion to fix it is to change the config.pro setting from "open_gl" to "win32_gdi". I've tried both settings and they make no difference. I throw down a challenge to anyone from PTC who is reading this. What does this mean? When will you get to the bottom of it? If you google this problem it shows up across the world with different ProE users and goes back to 2001.
CBenner
(To:GrahameWard)
I just did a search back on our network drive for Pro-E and found 56 std.out files with this error over the last year and a half or so... not counting any that got deleted over that time period.
Chris Benner
Autodesk ® Expert Elite
Darrell
(To:CBenner)
I see this all the time with our users. It seems to be a generic code for unexplained crashes. I think it means Pro/E crashed and we don't know why.
GrahameWard
(To:Darrell)
CBenner
(To:GrahameWard)
They're all over the map, depending on what our working directory was at the time... so there may have been hundreds that got overwritten in the last 3 years.
Chris Benner
Well, it is a generic/cryptic/useless error code, but I have encountered it usually when developing JLink applications.
In most cases the crash was caused by a problem in the text file that includes the messages and the most likely cause was either the lack of the two '#' signs at the end of the file or some garbled text in the middle.
Sometimes a simple editor like notepad might add some unreadable letters into the file, or use CR/NL sequences that JLink doesn't like. Notepad++ is very helpful to prevent these cases though.
It is a shame that PTC hasn't added some more useful explanations to their error messages, but.... well...
Just my 0.02$
Uriel
