Exiting a ProMousePick() loop to exit a dialog
  • March 24, 2016
  • 1338 views
I have inherited a application which creates a ProUIDialog. One of the pushbuttons activates a loop to allow the user to select items from a 3D display list.
The code for the mouse pick is:
while(1) {
status = ProMousePickGet (PRO_ANY_BUTTON, &button, screen_pt);
if ( button == PRO_MIDDLE_BUTTON || status != PRO_TK_NO_ERROR ) break;
Picking the middle mouse button exits the loop and makes the dialog active again. Is there any way to set the dialog cancel button (red X) to be enabled? I set ProUIDialogCloseActionSet() but when in the loop, picking the cancel button just rings a bell.
Any ideas?
Bob
    Hi all,
    Bob,
    Without knowing how the loop is constructed it is a shot in a dark...
    I would either insert a dialog close statement in a button check block:
    if( button == PRO_MIDDLE_BUTTON ... ) {
         ProUIDIalogUnload(); // check spelling
         break;
    or use a static module level variable which would be set depending on button pressed and an observer within a dialog code to react on a variable value.
    HIH.
    Feliks.
