Figure out maintenance release of Creo
davehaigh
Here's another way to figure out what maintenance release of Creo you are running. This looks at the install log in the Parametric folder.
Note that what I show here is for interactive testing. You will need to double up the % signs for your batch file.
for /F "tokens=2 usebackq" %A IN (`findstr "SHIPCODE" "c:\ptc\Creo 1.0\Parametric\uninstall\instlog.txt"`)DO set CREOVERSION=%A
set CREOVERSION="M020"
for /f "useback tokens=*" %a in ('%CREOVERSION%') do set CREOVERSION=%~a
set CREOVERSION=M020
In your batch file it would look like this:
for /F "tokens=2 usebackq" %%A IN (`findstr "SHIPCODE" "c:\ptc\Creo 1.0\Parametric\uninstall\instlog.txt"`)DO set CREOVERSION=%%A
for /f "useback tokens=*" %%a in ('%CREOVERSION%') do set CREOVERSION=%%~a
You can then use %CREOVERSION% to set the folder where you want to copy the loadpoint configs.
Obviously you need to change the hi-lited section to match your loadpoint.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
davehaigh
(To:davehaigh)
One more thing you might want to do in this script is make the config files in the load point read only.
attrib +R "C:\ptc\Creo 1.0\Common Files\%CREOVERSION% \text\config.pro"
attrib +R "C:\ptc\Creo 1.0\Common Files\%CREOVERSION% \text\config.sup"
David Haigh
