Figure out maintenance release of Creo
David,
Your method will be useful for those running more Creo apps than just
Parametric. We don't run anything else, so I just capture the build
from the folder:
rem ** sets Pro/E version
set proe_ver=creo_1
set proe_version_number=29
rem ** set load point
set proe_load_point=C:\Program Files\PTC\Creo 1.0\
rem ** Determine the build
for /f "delims=" %%A in ('dir /a:d /b "%proe_load_point%Common Files\")
do set BUILD=%%A
rem ** Set paths
set proe_text_folder=%proe_load_point%Common Files\%BUILD%\text\
set proe_executable_folder=%proe_load_point%parametric\bin\
set proe_executable=parametric.exe
I may change to your method, however, to future proof my files in case
we acquire Direct or some other app and have two build folders.
I think we covered this, but the old build folder does get removed when
a new build is installed, right?
Doug Schaefer
from the folder:
set proe_ver=creo_1
do set BUILD=%%A
rem ** Set paths
Doug Schaefer
