Flexnet Admin Server
Luar
Hi all,
I just want to know if this is possible?.
We have a customer case here, They want to transfer their license "Flexnet" in a virtual machine their reason is they want to lessen their workstation. Is it advisable to use virtual machine for Licensing?. If yes, What are the advantage and disadvantage?
Luar
6 REPLIES 6
MartinHanak
(To:Luar)
Luar,
we use virtual machines as license servers and have no problems.
Advantages
  • you are not dependent on real hardware
  • you can set fixed MAC address for virtual machine, therefore you do not need to transfer licenses when you move the virtual machine to different hardware
Disadvantages
  • you have to be familiar with virtualization
Martin Hanak
Martin Hanák
Thank you for the response. How about connecting in VM? is there a log issues? or any issue encountered by the client?
Luar
MartinHanak
(To:Luar)
Luar,
we have no issues.
Martin Hanak
Martin Hanák
TomU
(To:Luar)
Luar,
We too run all our servers virtually. As far as the clients are concerned, there is no difference.
Luar
(To:TomU)
Hi Tom,
What is needed for VM flexnet deployement, what are the things to consider or to prepare to apply that setup.
MartinHanak
(To:Luar)
Luar,
VM deployment is the task for your IT deparment. If VM is ready then get its HOST-ID (MAC address of network card) and ask PTC to move yor licenses to it. At the end install FLEXnet using Creo installation media.
Martin Hanak
Martin Hanák
