I am using Creo Parametric Release 7.0 and Datecode7.0.9.0
Fluid simulation study is grayed out. We have:
# Serviceable = Creo Simulation Live
# Feature Name = 379
# Feature Version = 40.0
# Number of Copies = 35
# Expiration Date = 30-jul-2023
# Module = Creo Simulation Live
Hi @rlash,
Ensure that license file contains feature CREO_SIMULATION_LIVE_FLUID (385) or CREO_SIMLIVECFD_SET (10138).
If the feature is present, reconfigure the Creo Parametric with correct license.
Hope this helps.
Vipul
I believe you need the Creo Simulation Live Advanced option for Live CFD.
Hi @rlash,
Hope this helps.
Vipul
