Hello friends, I wonder how I can reactivate my mapkeys that I already have because they are already in most settings when I perform the command does not do what it should.
will be that I will have to redo it again and the comondos save mapkeys again ....
grateful for the help .......
Hello Andre,
Mapkeys are created by recording picking step by step from "menu". I assume you want reactivate yours mapkeys b/c you reload Pro-E or up garde to newer version of Pro-E. If you still using WildFire then yes you still can reuse the mapkeys that you already have (store in config.pro). But if you are switching from Wildfire to Creo, b/c the "lay out" between WildFire and Creo are different. WildFire is using "menu" and Creo is using "tab". Depend on what you have, some of your mapkeys still work, but I believe most of them don't. Look like you have to create you mapkey from scratch.
DV
ok, it was just that we are migrating from WF4 for Creo 2.0 and has some mapkeys that I have yet to use the other not so much now thanks for the help, now is redo all .........
grateful ..........
