How to config Model Manager license when the license server moved from old to new server?
cnimkaew
I want to know which config file that can edit target the license for CoCreate Model Manager version 17.00?
MaxR.Kublin
(To:cnimkaew)
The License Server, as well as Database Server and File Server, are configured in the XML file you are using.
As a quick test, you can make a copy of your XML file located beneath %APPDATA%
The right solution is to edit the XML file on the Server (where your Database Server is running)
Hope this helps.
MaxR.Kublin
(To:cnimkaew)
Did you have a Chance to verify the solution?
I am 100% sure that my answer is correct since the task you describe is daily business for a Consultant.
