I am trying to clean up our drawing formats and set up some line styles. I am using the pen tables, but it appears that the drawing forms are using lines that controlled by the geometry pen and not the drawing format pen. How do I set the line style of my drawing format to be controlled by Pen 4 (Drawing Frame pen)?
1.]
If colored lines are plotted by pen number 1 then these lines are colored by user color
2.]
If you want to set different thickness to colored lines then you have to color them by system colors
3.]
Every system color has assigned its keyword (eg. drawing_color).
You can put the keyword into pen definition, for example:
pen 2 thickness 0.5 cm; drawing color
4.]
see https://www.ptc.com/en/support/article?n=CS148290
http://support.ptc.com/cs/cs_26/howto/plt522/plt522.htm
