I would need a help with config.pro setting so that i am not prompted to save changed (unsaved) objects.
in my config.pro file the option "prompt_on_exit" is set-up to NO...
Thanx in advance.
Default is no, so yes to this option much generate a different dialog than the "beware, you are about to mess up" prompt if you have changed objects in session.
Welcome to the forum, Tomas!
