How to insert start part template while making solid pipe in piping module ?
ppandarkar-2
We want to create solid pipe with default customized start part template.
We have set below config option -
pipeline_solid_start_part_name C:\PTC\Creo3.0\templates\start_part_template.prt.1
But every time we need to browse start part template -> apply then then make.
So is there any way to insert by default start part template while creating solid pipe. In below snap instead of None start part template should be applied.
start part template in pipingstart part template in piping
Prashant Pandarkar
Prashant,
Config option pipeline_solid_start_part_name is for Spec Driven piping.
Check article CS125325 for details.
Is there any option for for non spec driven piping?
- Prashant Pandarkar
Not an option available yet for Non-spec piping.
