I have an assembly which always opens up on the default rep rather than the master rep. All of my other assembly open up at the master rep so is not a config setting. I have tried to redefine the default rep to match the master rep in hopes that pro/e will then open up the master rep but it doesn't.
This same assembly is failing at the next higher assembly but it doesn't fail when you open it up individually. I believe it has something to do with the simplified reps.
I have searched the forum but couldn't find an answer. Could someone please help...I am going crazy with this...
Thanks!
