Hello Everyone,
I was wondering whether there is a solution to save a component without related part. For example, I have an A asm and it has related B and C part like attached model tree.
I would like to save just A.asm even if B and C parts were changed. When I looked for a solution, I found "save_object" setting. However, it has just "changed_and_specified" option but I need to just "specified" option.
In the meantime, I would like to say why I need that. I would like to write a special save application via J-link, so I need to manage saving status by myself.
If someone might find a config option or j-link method, it will be great for me.
Thanks in advance
it looks like you have to implement something like ...
Also ... you can put B and C into special directory with ReadOnly access and set following config.pro options
override_store_back NO
!*** NO ... Creo stores objects in their original directories. If you do not have write permission to the original directory, the configuration option save_object_in_current takes effect.
save_object_in_current NO
!*** NO ... Creo does not save the object in the current directory.
Hi Martin,
Thanks for your alternative solution. SavingTime is good recommendation for me. However, I was wondering whether there is s solution in Creo side or not.
