How to see wireframe behind activated model
In Creo 2, when you had an activated model, you could see the lines and holes of other parts thru the activated part. I don't remember if this was only when the activated model was transparent or not, but I miss this! Now you can only see the workplanes or centerlines thru the activated part. Is there a new config setting that I am missing?
Please Help!
Dan
