Hello!
I need help for the WRITING of Mapkey to load (import) another mapkey.
Of course I can record a Mapkey for this, but the content is to big (I think).
Im sure, there is more slim way for this.
Actually I wish just to import a mapkey without to open a window, browse and select the file and close the window.
How looks it?
Thank you!
You may want to review this thread:
https://community.ptc.com/t5/System-Administration/Mapkey-Writing-Editing-Tips/td-p/443729
If you are asking how to call one mapkey from another the second mapkey is simply proceeded with a % character
!== Mapkey to call another Mapkey "abc" (mcm)==
mapkey mcm @MAPKEY_LABELThis mapkey calls another mapkey;\
mapkey(continued) ~%abc;
If you are asking how to load in a mapkey from a config.pro file into session then you record one clicking File-> Options -> Configuration Editor -> Import/Export -> Import configuration file
The mapkey will change depending on what version of Creo you are using but it will look generally like this:
mapkey(continued) ~ Select `main_dlg_cur` `appl_casc`;\
mapkey(continued) ~ Close `main_dlg_cur` `appl_casc`;~ Command `ProCmdRibbonOptionsDlg` ;\
mapkey(continued) ~ Select `ribbon_options_dialog` `PageSwitcherPageList` 1 `ConfigLayout`;\
mapkey(continued) ~ Select `ribbon_options_dialog` `ConfigLayout.ImportExportBtn`;\
mapkey(continued) ~ Close `ribbon_options_dialog` `ConfigLayout.ImportExportBtn`;\
mapkey(continued) ~ Activate `ribbon_options_dialog` `ConfigLayout.Open`;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;\
mapkey(continued) ~ Activate `file_open` `file_open`;\
mapkey(continued) ~ Update `file_open` `Inputname` `C:\\folder\\config.pro`;\
Thank you!
