Import parasolid file
Mahi_Jadeja
3-Newcomer
I am using Creo Parametric Release 6.0 and Datecode6.0.6.0
Parasolid files (x_t) when imported in CREO 6.0.6.0 not visible but it is opening and visible in CREO 10.
Martin Hanák
Martin Hanák
BenLoosli
(To:Mahi_Jadeja)
What version is your Parasolid file?
It should be above R30 as it is not opening in creo 6.
Is there any method to check
open the file in Notepad. Maybe you will see some version information in file header,
Martin Hanák
see https://www.13thmonkey.org/documentation/CAD/Parasolid-XT-format-reference.pdf
page 3
SCH_1200123_12006
This example denotes a file written by Parasolid V12.0.123 using schema
number 12006
Martin Hanák
