Is Creo 9 parametric covered by student license, also Creo 8 runs impossibly slow and crashes
CN_9791007
2-Explorer
I have been using Creo for a couple years. I recently replaced my hard drive several months ago and now am trying to reinstall Creo parametric. I installed Creo 9 by following the links for the Student Version (because I am still a student, after which I would become an educator). I installed Creo 9 and ran the program and it said that the Student License doesn’t support Creo 9 however the PTC website seems to indicate that it does.
when installing Creo 9.0 you have to use following information:
K-12 students can use Product code BE900908EDSTUDENTEDK12
University students can use Product code BK900908EDSTUDENTEDUNI
https://apps.ptc.com/schools/references/install_creo9_unistudent_standard.pdf
https://apps.ptc.com/schools/references/install_creo9_schools_standard.pdf
Martin Hanák
BenLoosli
(To:CN_9791007)
You may need to obtain a new license file for Creo 9.
Also, the student edition uses a modified file format so a normal download of Creo 9 will not work.
Martin Hanák
is there a new code for 2024? as i am struggling right now
Creo 9.0 product codes remain the same.
Creo 10.0:
https://apps.ptc.com/schools/references/install_creo10_schools_standard.pdf
https://apps.ptc.com/schools/references/install_creo10_unistudent_standard.pdf
Martin Hanák
