Issue with License Activation via License Indicator – Status "Not Eligible"
LK_13278604
2-Explorer
Dear PTC Support Team,
I am reaching out for assistance with an issue I’m experiencing while trying to activate a license using your License Indicator. I received an order number from my university and have been trying to generate a valid license based on that.
While I am able to request the license and it does appear in my files, the status is always shown as “Not Eligible.” I have already attempted several steps to resolve the issue, including:
  • Deleting and reinstalling the license files
  • Creating a new PTC account with a different email address
  • Reinstalling the software entirely
Unfortunately, none of these steps have resolved the issue, and the license remains unusable.
I would appreciate your support in resolving this. If you require any additional information, such as the order number or screenshots, I will be happy to provide them.
Thank you in advance for your help.
Best regards,
Leandro Knoop
Technical University Braunschweig
Hi @LK_13278604
You may try information in article https://www.ptc.com/en/support/article/CS343103
I hope this will help.
1.]
BK100908EDSTUDENTEDUNI code enables you to install and run Creo Parametric up to 10.0 version.
2.]
BK100908EDSTUDENTEDUNI_license.dat contains locked license, because of that you must not install license manager as described in CS343103.
3.]
The described problem may be caused by the license file being generated for an incorrect network card MAC address.
To confirm this, I need to see the contents of your license file as well as the output of the ipconfig /all command.
Open Command prompt window, run ipconfig /all > ip.txt command and upload ip.txt file.
Martin Hanák
Hi @LK_13278604,
Anurag
