I am using Creo Direct Release 5.0 and Datecode5.0.2.0
借用许可无法正常归还,客户端无法正常使用。许可借用出服务器到客户端上,无法提前归还。
The borrowing license cannot be returned normally, and the client cannot be used normally. The license is borrowed from the server to the client and cannot be returned in advance.
please read following documents
https://www.ptc.com/en/support/article/CS347071
https://www.ptc.com/en/support/article/CS336324
Take a look at this discussion - "License Return Issue": https://community.ptc.com/t5/System-Administration/License-Return-Issue/td-p/662722
