Licensing of Pro/Engineer Wildfire 4.0 under Windows 10
felixb
2-Explorer
Dear all,
I am trying to use my Student edition of Pro/Engineer Wildfire 4.0 under Windows 10. Installing the software was no problem at all. I can also access my account. But I cannot get a license file. The system puts out "Invalid parameter values have been passed in. The application cannot continue." I tried several ways as mentioned on the PTC website to get the host-id and there are two ids. One for my ethernet adapter and the other one for my wifi adapter. Apparently my install runs on the ethernet adapter. Even having figured out this I cannot get a license file. Is there another way to get it or edit my old license file?
Best regards
Felix
2 REPLIES 2
MartinHanak
(To:felixb)
@felixb wrote:
Dear all,
Best regards
Felix
you try following:
  • download Creo 6.0 installation media
  • install Creo 6.0 (K-12 students can use Product code BE600908EDSTUDENTEDK12, University students can use Product code BK600908EDSTUDENTEDUNI)
  • hopefully you will get Creo 6.0 license file (located in C:\ProgramData\PTC\Licensing directory)
  • use Creo 6.0 license file to configure Pro/Engineer Wildfire 4.0 startup command
Please read following documents, too.
https://apps.ptc.com/schools/references/install_creo6_schools_standard.pdf
https://apps.ptc.com/schools/references/install_creo6_unistudent_standard.pdf
Martin Hanák
Dear Martin,
thanks for your mail and the hint. I hoped that there could be an easier solution. I will try your suggestion as soon as possible.
Best regards,
Felix
