Limiting users to one license
  • November 27, 2012
  • 2 replies
  • 1997 views
You can limit users to one license. You have to do it in the ptc.opt file.
From my ProE admin 101 talk from PTCUser 2010:
Appendices’ – Licensing Options File
• You can use the options file to limit users to running one copy of ProE at a time.
Tell me if I am wrong but I think if you have two different licenses they could still open one license of each. Therefore two licenses opened by one user at the same time.
Steve G
davehaigh13-AquamarineAuthor
The example I gave reserved licenses for a group. However tpi 129441 shows how to reserve only one license for each individual user.
David Haigh
Hi there,
I have a problem about floating license after internet connection lost, after losting license on that computer, and wanting to re-run Creo on it, I get the message of maximum number of users already reached .. even if not any session of Creo is running.
I think I have to release (in some way) the license, so, how can I do that?, thanks very much!.
Thanks, I solved the problem by using batch files already included ... ptcstatus and ptcflush.
Thanks again.
