Load Model Tree when starting Creo
BenLoosli
We have a modified model tree that has some columns added and features turned on by default. This was been saved as a tree.cfg file. The question is how can we either set these things that we put in the tree.cfg file from config.pro settings or open a model tree setting file from config.pro so it is set automatically.
Ben,
A while back I downloaded a complete list of config.pro parameters. One of them is:
mdl_tree_cfg_file
described as "Specifies the Model Tree configuration file to be loaded when Creo is started"
Maybe that's the magic parameter?
Other than that, the only other place I can think is maybe the config.win file? That one is a cryptic (to me, anyway) bunch of stuff, but might be good for something.
Ben,
mdl_tree_cfg_file
Yes, that's the option. Point that to your tree.cfg file.
There is no more config.win file, that went away with Creo 1. It's now the creo_parametric_customization.ui.
LinkedIn
