Mandatory Values error message
cdenham
I am currently trying to install Creo parametric Education program, however during install at the license identification stage when i input my product code it highlights an error message stating "please provide mandatory values"
Any help would be appreciated with this cheers
please publish a picture of installation dialog box.
MH
Martin Hanák
When hovering over the error message it says "Please provide mandatory values"
maybe installation assistant is not able to recognize network card in your PC.
Open Command prompt window and run following command
ipconfig  /all  > ip.txt
and publish the contents of ip.txt file. I can check information for you.
MH
Martin Hanák
Hi Martin,
ran into the same issue today. Here's my ipconfig output.. I also put a (random) entry (from https://raw.githubusercontent.com/mapix/ruijiehacker/eb3b5d46eb22695c918e37a7fcd814854f30fcc7/About%20Reg/qw.reg) into HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkCards as wine was complaining about that (Error: No subkeys found: SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkCards).
I would guess that creo is actually very close to working on a recent wine (staging) version. There must be some talented linux geeks among PTC devs who can help resolve the remaining issues?
#regards
