Mechanica not using up available system memory
We are running Creo Elements/Pro 5 64-bit on Windows 7 Professional 64-bit.
For some reason, Mechanica is running very slow but it's not using the available system memory. It seems that Mechanica is using very little RAM and mainly using the Hard Disk while it's calculating.
We have 6GB of RAM and have 3.2GB available while Mechanica is running. Mechanica is making the entire system run slow and it seems that it's using lots of disk space to run.
How can we make Mechanica use up the available RAM?
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
