I am using Creo Parametric Release 6.0 and Datecode6.0.6.0
I am trying to add notes in 3d space under the annotations tab. I have done this before (I do this almost everyday) but for some reason, now, when I use the middle mouse button to set the location of the note, it cancels the operation altogether. This function is still available in 2d space and works just fine.
Hi DM_10541379,
Welcome to the PTC Community!
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Anurag
