Mistake with Skeleton file
jlozano
(Note: I am using Creo Elements/Pro5.0 and Windchill)
I am working with a small assembly that molds parts, so I use a skeleton of the final molded part.
Normally I create the final molded part and create a skeleton in the assembly based on the final molded part.
After everything was completed I uploaded the assembly into Windchill.
The customer asked that the molded part be changed to add some features. I made the changes and saved, and then did a save as to what I thought was the skeleton.
The huge mistake I made was I thought I had the part file open and was saving over the skeleton, but the opposite was true.
SO now I have my final part behaving as a skeleton file.
Is there any way to change this back to a standard part file? Normally I would just delete the last saved copy (i.e. mold.prt.5) and work from the copy from before I messed up the model. But now that we use windchill I have no access to the previously saved part files.
Please help.
0 REPLIES 0
