Modelcheck 'Remove Unwanted Parameters'
nhanratty
All
I am using the start file config option PRT_PARAM_UNWANTED and using it to remove a parameter called ALPHA but it's not working - the parameter remains in the updated file.
Other config options are working fine, such as PRT_PARAM_RENAME and PRT_PARAMETER. I have assembly versions of these options also in the file if that makes any difference...
The log file lists a few errors which I don't understand..below is the log for just one part. If anybody can shine any light on what is happening I would appreciate it.
ERROR: LINE=01450721.prt.1
0 REPLIES 0
