I have an old Spaceball 3003 FLX running on XP Pro 64 bit system using a driver that I've had for quite some time. The driver is a 3DConnexion 3DxWare Version 3.2.0 build 5, firmware version 2.62. The spaceball works just fine but the sensitivity default is 50, and I would much rather have it at 100. The problem is that everytime I change windows it switches back to the default. I've tried saving a profile with the sensitivity set to my preference, but it doesn't fix the problem.
Anyone seen this? Anyone have a fix? Anyone have a "newer" driver for this Spaceball? In the past, I've tried using the drivers that were available from 3DConnexion, but none worked. The driver I did find was via an individual who was kind enough to archive it.
I'm at a loss as to why this problem cropped up now; other than the 64 bit change, everything else is essentially the same as I've used for more than 15 years. Maybe it's time to buy something new? On that subject; what are the alternatives? $300 for a new space explorer seems bad. I've tried (still have in fact) the Space Navigator but didn't really like it. Guess I could try again... but I'm wondering if someone knows what model spaceball has specific 64 bit XP drivers?
thanks in advance...
Paul Korenkiewicz
FEV Engine Technology
www.fev-et.com
