Fact A black or white background will display when image with transparent background is inserted as an Object in a format file is a working as designed behavior, refer to article :
it is not clear from your post if using transparency on import is part of the problem. This may help with the transparent background issue.
Thank you for answering my question. My main problem is how to insert a PNG image with a transparent background in the format file. I saw that it is possible to insert a PNG image with a transparent background in the drawing file, but in the format file, it seems that the image can only be inserted through OLE by inserting objects. I imported it through the built-in drawing software on my computer, and the background has become opaque and pure white.
The above two images are the appearance of imported images in a format file. The transparent background of the image has changed to a white background
The above image was imported from a drawing file with a transparent background
ask PTC support to let you know if it is possible to instert png in a format with a transparent background.
I guess such functionality is not implemented and you will have to use drawing template instead of format.
That's a bit regrettable... But thank you for your reply!
