Is anyone able to create a PTC Case?
My logger does not let me select ISSUE TYPE, which is required.
The PRODUCT options no longer include a generic Creo Parametric, only a "Connected" option.
Look at this image
This issue was fixed and I was able to create a case the next day.
Seems fine to me. Just don't pick 'connected' on this first screen:
If for some reason you do, you can always 'return to start':
