Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
All, I have found the "Using the PTC Day-in-the-Life Performance Benchmark " technical brief document on ptc.com and it says that 45 tests were used to formulate the results. It lists those 45 tests but doesn't give detail as to exactly what menu selections were made to perform each test. Is there another guide that I am missing? Or has the day-in-the-life test not been released to customers yet?
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110 [cid:image001.jpg@01CC2449.AB6C8450]
Many PTC customers use the Windchill Pro/ENGINEER Data Management Performance Benchmark Test, a simplified version of the benchmark, for daily monitoring of Windchill performance.
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110 [cid:image002.jpg@01CC244A.D4E10BC0]
