PTC Day-in-the-Life Performance Benchmark
pwilliams-3
All,
I have found the "Using the PTC Day-in-the-Life Performance Benchmark " technical brief document on ptc.com and it says that 45 tests were used to formulate the results. It lists those 45 tests but doesn't give detail as to exactly what menu selections were made to perform each test. Is there another guide that I am missing? Or has the day-in-the-life test not been released to customers yet?
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110
[cid:image001.jpg@01CC2449.AB6C8450]
Bah, I needed to read the fine print.
Many PTC customers use the Windchill Pro/ENGINEER Data Management
Performance Benchmark Test, a simplified version of the benchmark, for daily
monitoring of Windchill performance.
[cid:image002.jpg@01CC244A.D4E10BC0]
