I have tried to use PTCStatus and get a message back saying,
">ptcstatus
'x86e_win64_ptc_setvars' is not recognized as an internal or external command,
operable program or batch file.
'ptc_setvars.bat' is not recognized as an internal or external command,
Could Not Find <proepath>\bin\ptc_setvars.bat
The system cannot find the path specified."
Any clue what I need to do?
Thank you,
[cid:image001.jpg@01CC2A94.EA04A0C0]
The information contained in this electronic mail transmission is intended by Weil-McLain & for the use of the named individual or entity to which it is directed and may contain information that is confidential or privileged.  If you have received this electronic mail transmission in error, please notify the sender of the error by reply email so that the sender's address records can be corrected and delete it from your system without copying or forwarding it, including any reply records.
This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread.  You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
