PTCsetup doesn't work
MarcoLoli
Hello to everybody,
I'm trying to install some license extension (Advanced Rendering) but I'm having problems when I launch the PTCsetup.bat.
A DOS windows comes up for a while and nothing happen later.
My system is a WinXP 32bit, PROE is WF4 M100.
Any suggestions?
Thanks in advance.
Hi
If you need to reinstall ProE, you go to the directory: proe_WF4_loadpoint \ bin \ and run there ptcsetup.bat
In the event that the system can not run the file ptcsetup.bat, you can start the installation directly from:
proe_WF4_loadpoint \ dsrc \ i486_nt \ obj \ ptcsetup.exe
Vladimir
Best Regards,
Vladimir Palffy
Thanks a lot Vladimir,
but unfotunately also the ptcsetup.exe doesn't work.
Any other suggestions?
I suppose that the base license works.
Open license file and find:
# Serviceable = Creo Elements/Pro FPL REP Package (formerly Pro/ENGINEER)
# Feature Name = 283
# Feature Version = 31.0
# Number of Copies = 1
# Expiration Date = 31-aug-2011
# Module = Advanced Rendering Extension 2
When not working ptcsetup.exe, you can add to license information about running modules manually into *. psf file.
Opening file (example .... loadpoint \ bin \ proe1.psf): and add number "283" behind name of your license.
Information is necessary to add at the end of the line in between brackets (283):
ENV=PROE_FEATURE_NAME
For example:
ENV=PROE_FEATURE_NAME=NAME_OF_YOUR_LIC (283)
in your *.psf file.
The numbers in between brackets defines the startup type of running licenses.
Best Regards,
Vladimir Palffy
