I am trying to prevent users from launching Creo if they are not using the company startup script. I start with no psf file in the <load point>/bin folder (deleted it as part of the install). Then I copy the psf into the bin folder, launch Creo and then delete the psf file.
Is there another way to do it? Deleting the psf file so quickly after launching Creo leaves me a little leery although it appears to be working. I tried putting the psf into a different folder other than the bin folder and calling it from the start up script but I wasn't able to get that to work. That could entirely be me.
I have users that launch Creo from the start menu or pin the program to their task bar and then complain when the program isn't behaving the way that it should (because they aren't using the company settings).
