I am using Creo Parametric Release 11.0 and Datecode11.0.3.0
The Preview File button has disappeared from the File Open window. I use this feature all the time. Please advise how to restore the function. I have searched the config options but no luck. Thanks.
Hello @ptc-1920637
You may need to enable toolbar in File > Open dialog box.
As shown in image RMB > Browse Toolbar to enable Preview.
https://www.ptc.com/en/support/article/CS410314
I hope this will help.
Thanks.
Are you sure the files were saved in a manner to support the preview functionality? Is preview functionality not working on all files or just on some?
Hello @ptc-1920637
Thanks.
